Measure voltage with 2182A using Matlab
ilanha
Post by ilanha » July 4th, 2016, 5:41 am
My measurement system includes a 2182A nanovoltmeter and I'm trying to meausre voltage with it using matlab (connected through GPIB).
I tried the following:
fprintf(nV_obj,'*RST');
fprintf(nV_obj,':SYST:AZER:STAT OFF');
fprintf(nV_obj,':TRACE:CLEAR');
fprintf(nV_obj,':TRACE:POINTS 100');
fprintf(nV_obj,':TRAC:FEED:CONT NEXT')
fprintf(nV_obj,':TRAC:DATA?');
reading=fscanf(nV_obj);
But I get an error:
Warning: Unsuccessful read: GPIB: NI: An I/O operation has been canceled mostly likely due to a timeout.
I also tried to use 'READ?' but I got about 0.1 mV when it is suppose to be almost zero (I know because when I do the measurement without matlab, that's what I get).
Would be glad to get some help...
Re: Measure voltage with 2182A using Matlab
Post by Dale C » July 12th, 2016, 7:59 am
Your code is setting up the TRACE buffer. But I see no trigger to take the data.
TRACE:DATA? is the command to retrieve the data but there is no data because of no trigger.
