Hi all
I have 2 2100 6.5 Digit Multimeters, I want to measure current on one and voltage on the other, and log them both into excel.
I have tried running separate instances of Excel, but can't seem to connect to both at the same time. I am happy to record the data into separate spreadsheets if that is required.
I am running Windows 8.1, Excel 2016 and KI 2.04.
Thanks for any help.
Recording 2 2100 6.5 Digit Multimeters to Excel
Jump to
- Announcements
- Customer Support
- ↳ Product Support
- ↳ Oscilloscopes
- ↳ 5 Series MSO Oscilloscopes
- ↳ Programming Support
- ↳ Passive/Low Voltage
- ↳ High Voltage
- ↳ Differential
- ↳ Current
- ↳ Signal Sources
- ↳ AFG1000/2000/3000 series
- ↳ AWG5000/7000/70000 Series
- ↳ Keithley 3390
- ↳ TSG4100A Series
- ↳ Spectrum Analyzers
- ↳ Announcements and FAQs
- ↳ RSA Programming
- ↳ RSA5000/6000 Series
- ↳ Vector Network Analyzers
- ↳ TTR500 Series VNAs
- ↳ 2600 Series SourceMeter
- ↳ 2400 Series SourceMeter
- ↳ Series DMM7510 Graphical Sampling DMM’s
- ↳ Other DMM's
- ↳ 7000 Series Switch
- ↳ 700 Series Switch
- ↳ RF Switch
- ↳ Other Switches
- ↳ Power Supplies
- ↳ Series 2300
- ↳ Other Power Supplies
- ↳ Power Analyzers
- ↳ ACS Software Products
- ↳ Nanovoltmeters
- ↳ Electrometers
- ↳ Curent Amplifiers
- ↳ PicoAmmeters
- ↳ Current Sources
- ↳ Bit Error Rate Testers
- ↳ Logic Analyzers
- ↳ Video Test
- ↳ Other Instruments
- ↳ Electronic Loads
- ↳ Frequency Counters
- ↳ Software
- ↳ TekScope Anywhere
- ↳ SourceXpress
- ↳ SignalVu-PC
- ↳ PWRVIEW
- ↳ KickStart
- ↳ Test Script Builder
- ↳ LabView Drivers
- ↳ IVI Drivers
- ↳ TekVISA
- ↳ ExcelLINX
- ↳ IVy
- ↳ Keithley I/O Layer (KIOL)
- ↳ Accessories
- ↳ Test Fixtures
- ↳ Cables and Connectors
- ↳ Application Support
- ↳ Low Current Measurements
- ↳ Low Voltage Measurements
- ↳ Resistivity Measurements
- ↳ Hall Measurements
- ↳ Electrochemistry
- ↳ Solar Cell Measurements
- ↳ High Brightness LEDs
- ↳ General Discussion
