Keithley 2001 and 7001 combo for 4 wire resistance measureme
nibin89
Country: Indonesia
Post by nibin89 » February 29th, 2012, 8:05 pm
Please provide a LV driver block for the Keithley 2001 which can be directed to read 4 wire measurement from a specific channel.
ie,
i need to measure 4 wire resistance reading from 20 channels in 4 wire from 7001 with 7011 scanner card.
I close the required channels from 1 to 20 one by one.
Then after each channel is closed, i need to direct the K2001 to scan that closed channel. (ex 1!1 or 1!8 etc)
In the present driver provided in the keithley website, there is no provision to input the scan address.
Please help.
Vince W
Re: Keithley 2001 and 7001 combo for 4 wire resistance measu
Post by Vince W » March 20th, 2012, 4:23 pm
Please provide the specific Keithley LV driver call you are calling and the arguments you are passing. Then, please provide the arguments you do not have that would satisfy your requirements. I do not fully understand the gaps in our LV driver that you are describing.
Vince W
