2260-30-36 Remote Monitoring
2260B-30-36, 2260B-30-72, 2260B-80-13, 2260B-80-27
jtrexr2
Post by jtrexr2 » October 26th, 2015, 1:00 pm
The Programming Manual says that there is a webserver option for the 2260, but when I configure LAN/webserver and go to the IP address assigned to the 2260, I get a welcome page with a link to the Keithley website. Is there no possibility of remote monitoring or reporting of measured current through the web server?
Re: 2260-30-36 Remote Monitoring
Post by Dale C » October 27th, 2015, 5:48 am
The internal web page is minimal.
I would suggest to use the Labview driver examples.
There is an example VI that controls the power supply parameters.
jtrexr2
Post by jtrexr2 » October 27th, 2015, 6:52 am
Where is this example? And would this be through the USB connection?
Post by Dale C » October 27th, 2015, 8:27 am
The example is located within the Labview driver. You will find it under "examples".
And it is VISA based so yes, it will work with USB.
Here is the link for the Labview driver for the 2260B.
http://www.keithley.com/support/data?asset=58092
Return to “Series 2260 Programmable DC Power Supplies”
