Chaining DMM7510 with DIN to BNC trigger cable Model 8503
Forum rules
<t></t>
DanMat
Country: Brazil
Post by DanMat » October 7th, 2020, 8:00 am
I need to trigger the multimeter (DMM7510), but it does not respond to the command from the other instrument (Keysight 33220A). I use the DIN to BNC trigger cable (Model 8503) to connect the equipment.
Do you have any idea of what could be the problem?
Thank's
Regards
Daniel M.
Re: Chaining DMM7510 with DIN to BNC trigger cable Model 8503
Post by Andrea C » October 21st, 2020, 6:18 am
Can you put a scope on it and verify that the trigger is delivered to the DMM7510? The EXTTRIG should be the input trigger to the DMM7510.
How are you setting up the DMM to use the trigger source?
