2182A error messages
2182 Series Support
cspin2013
Post by cspin2013 » January 12th, 2015, 1:15 pm
I am using the VI 'K2182Read1.vi' attached to read the channel 1 of my 2182A Nanovoltmeter. My laptop is connected with the nanovoltmeter through a GPIB-USB cable, and I am using LabView 2013. Whenever I run the program to read a voltage signal, the 2182A generates a beep, and the front panel displays 'ERROR: -101' and then 'ERROR: -110', although the readings seem to be correct. I don't know what causes these errors. Please give me some advice if you know to fix my problem.
Thank you very much.
K2182Read1.vi
(13.73 KiB) Downloaded 1154 times
Joseph V
Re: 2182A error messages
Post by Joseph V » January 12th, 2015, 2:15 pm
The -101 and -110 are both syntax errors so as such you may not have entered a parameter correctly or mistyped somewhere in your code, i.e using a "," instead of a "."
If you can save the vi for labview 2012 I would be able to look at the vi and see where the error is coming from.
-Joe
cspin2013
Post by cspin2013 » January 14th, 2015, 1:53 pm
Hello Joe,
I just attached a screenshot the block diagram of my labview vi and a LV2012 version of my labivew vi.
Thanks a lot.
block diagram of my vi
K2182Read1.vi
LabView2012 version
(14.48 KiB) Downloaded 1136 times
Joseph V
Post by Joseph V » January 15th, 2015, 6:47 am
Hello
On the third write block you have it as :SENS:VOLT:CHAN1:RANG:5e-3 where is should be :SENS:VOLT:CHAN1:RANG 5e-3 so that extra colon is what was giving you the error.
Attached is the fixed VI.
-Joe
K2182Read1 (1).vi
(13.49 KiB) Downloaded 1144 times
cspin2013
Post by cspin2013 » January 15th, 2015, 2:25 pm
Hello Joe,
Thanks for correcting my syntax error. Actually I just copied that command from the quick reference guide that came with the nano-voltmeter.
When I tried to set auto-range, both ':SENS:VOLT:CHAN1:RANG:AUTO ON' and ':SENS:VOLT:CHAN1:RANG AUTO ON' generated message 'Error:-101'.
Do you know how to fix this problem?
Thank you.
Return to “Nanovoltmeters”
