Reading 2 channel data simultaneously in 2182A nanovoltmeter
2182 Series Support
sausgh
Post by sausgh » February 8th, 2015, 6:53 am
Dear All,
I wrote a simple Labview program to read the voltage. I did it for one channel and it is measuring fine way. My purpose is to measure the voltage at two point at the same time, so I need to read the voltage at both channel at a time. Anyone can help me regarding this.
Thanks & Regards
Saurabh
Re: Reading 2 channel data simultaneously in 2182A nanovoltm
Post by Dale C » February 9th, 2015, 6:26 am
There is only one A/D converter in the Model 2182A.
So true simultaneous measurements are not possible.
One channel needs to be selected and then take a reading.
Then switch to the next channel and take another reading.
Look at the trigger model on page 7-5, figure 7-2 of the Model 2182A user manual.
Here is the link.
http://www.keithley.com/support/data?asset=15977
The Device action shows the channel in the device action.
So each reading detects the present channel.
Return to “Nanovoltmeters”
