K2182A lemo cable broken
2182 Series Support
mhirschb
Post by mhirschb » September 25th, 2012, 3:31 pm
in my lab, we have a K2182A with the supplied cable (http://www.keithley.com/products/dcac/s ... ?mn=2107-4). Unfortunately, one of the terminating copper spade lugs has broken off, and these parts cannot be re-used (they are clamped together when the wire is fixed to them). Can anyone tell me where I can buy these lugs individually?
Best,
Max
RaymondR
Re: K2182A lemo cable broken
Post by RaymondR » September 28th, 2012, 7:38 am
Hi mhirschb,
The Keithley part number is 2182-316.
RadioShack may sell the copper spade plug and crimp parts that are at least similar to what you need.
You may also be able to fashion the plug from a thin copper washer, some wire cutters, and a pair of pliers. Make sure that you're using pure copper and clean the material before and after working with it. You'll want to remove any oxidation before attaching your wire to it.
You'll want to bend the wire in half before crimping and make sure to use shrink wrap.
After reconstructing the plug, make sure to compare some test measurements against your other set of two plugs.
mhirschb
Post by mhirschb » September 28th, 2012, 12:01 pm
Many thanks!
Return to “Nanovoltmeters”
