rates changed to slow when read voltage through K6221 RS232
2182 Series Support
hachiko
Country: China
Post by hachiko » July 10th, 2013, 9:21 pm
set 2182A rates to Medium first, then I read a measurement through command "SYST:COMM:SER:SEND MEASURE:VOLT:DC?", the rates is automatically changed to slow, why?
2182A is connected to 6221 through RS232, 6221 is GPIB connected to PC.
And I found, It is very slow to get reading from 2182A through 6221 RS232, it takes about 2-3 seconds
Re: rates changed to slow when read voltage through K6221 RS
Post by Dale C » July 11th, 2013, 5:30 am
The :MEASURE:VOLT:DC? query command resets the function of DCV to *RST conditions.
I would use the following code instead.
:SENSE:FUNC 'VOLT:DC'
:READ?
That should keep the DCV function in MEDium speed.
hachiko
Country: China
Post by hachiko » July 12th, 2013, 7:07 am
Thanks.
F_CHEM_
Country: United Kingdom
Post by F_CHEM_ » April 16th, 2015, 10:02 am
Hi, I have a similar Issue.
Is it possible to change the *RST defaults so that the 'MEAS:VOLT:DC?' function does uses fast?
Post by Dale C » April 16th, 2015, 12:26 pm
The *RST condition are set. They are not programmable.
If you send :MEASE:VOLT:DC? then the default NPLC, which is 5, is selected.
F_CHEM_
Post by F_CHEM_ » April 16th, 2015, 1:14 pm
Cheers Dale
Will have to give my programme more thought
Return to “Nanovoltmeters”
