Keithley communicator throws error
Gregor
Country: Argentina
Post by Gregor » September 12th, 2019, 6:53 am
Hi, I am trying to drive the Keithley 6485 with the program Keithley communicator.
The - was succesfully added in Keithley Configuration Panel (I used a RS232 cable).
When I try to open the program Keithley communicator I get the next message:
"An error program occured when initializing
Invalid procedure call or argument....."
What can be the problem? What can I do?
Thanks!!
Re: Keithley communicator throws error
Post by Andrea C » September 13th, 2019, 4:13 am
Are you saying the Keithley Communicator cannot successfully run?
Or does the software run, but is not successful to connect to the 6485 over RS-232?
Stuart M
Keithley
Keithley
Post by Stuart M » September 20th, 2019, 1:57 pm
See the problem here too on both windows 7 and windows 10 systems.
The latest windows updates corrected problems on all systems here.
Gregor
Country: Argentina
Post by Gregor » September 24th, 2019, 12:36 pm
Thanks! I was able to solve this problem.
I have correctly installed the programs "Keithley Configuration Panel" and "Keithley Communicator". In addition, the pc recognizes my Keithley 6485. Now we want to record the current at different times with the -. To do this, Do I need to install LabView and do a routine? or what program do I need?
I am sorry, I am a beginner in all of this :(
Stuart M
Keithley
Keithley
Post by Stuart M » September 25th, 2019, 8:29 am
I don't see a LabVIEW driver for the model 6485.
So before writing your own code, I would first try KickStart 2 (comes with a 60-day trial) and connect your 6485 using GPIB.
KickStart support 6485 DC Current measurements and collects data and graphs the results.
Download can be found here:
https://www.tek.com/software/kickstart/2-1-0
Gregor
Country: Argentina
Post by Gregor » September 30th, 2019, 12:24 pm
Thanks! I'm going to try this program.
Can KickStart Instrument Control be used with the instrument connected by RS232 cable to the pc? or is it obligatory to use KickStart with the - connected by a GPIB cable?
Stuart M
Keithley
Keithley
Post by Stuart M » September 30th, 2019, 12:48 pm
KickStart currently supports GPIB, USB, LAN connections to a variety of instruments.
(see release notes for full list of instruments..)
The product page gives an oversight..
https://www.tek.com/keithley-kickstart
Return to “Keithley I/O Layer (KIOL)”
