compatibility issue
6514, 6517 Support
Priya K
compatibility issue
Post by Priya K » January 3rd, 2019, 12:16 am
I am using windows 8 and I have a Keithley 6517A meter. I am trying to
interface the both by downloading NI VISA. Currently I have tried VISA
version 17 and 18. However, I am still unable to interface the Keithley.
When I try to initialize KI GPIB by sending command *idn?, I get status as
8=timeout. Kindly suggest me a solution to this problem at the earliest.
Re: compatibility issue
Post by Dale C » January 3rd, 2019, 8:14 am
Is Model 6517A set for GPIB? If so, what address?(default is 27).
Since you have NI-VISA, you should have NI-MAX.
Use NI-MIX to see if you can control the 6517A with *IDN?
Return to “Electrometers”
