on battery?
428 Support
cristi
Country: Netherlands
on battery?
Post by cristi » January 25th, 2013, 6:59 am
Dear Sir,
Can 428-Prog work on battery? If so, what shoud I do? If not, is there another currrent source from you that works on battery?
regards
cristian
Re: on battery?
Post by Dale C » January 25th, 2013, 8:41 am
The Model 428-PROG operates only on line power.
There are no battery operated instruments from Keithley.
Kenneth P
Re: on battery?
Post by Kenneth P » January 25th, 2013, 8:52 am
Hello Cristian,
The Model 428-PROG does not have a battery option. I believe you are looking to get improved noise level performance since a battery power source does not introduce noise associated with AC power supplies. I recall that there is a programmable current amplifier with a battery option offered through Stanford Research. It is the Model SR570. You might want to consider this model if the noise level performance of your 428-PROG is not sufficient for your test needs.
cristi
Re: on battery?
Post by cristi » January 25th, 2013, 11:49 pm
Thank you for the replies.
I have a different problem. I would like to use the source for testing on people and, because of safety, I would prefer the battery device.
The current will flow directly into the body. What I need is a configuration in which I want to be sure that, no matter what, there is no harm.
regards
cristian
Re: on battery?
Post by Dale C » January 29th, 2013, 6:08 am
No Keithley products are designed to be connected to humans.
Return to “Curent Amplifiers”
