smallest current compliance of 6487 when output 250V ?
2502, 6485, 6487 - Support
txz033000
Post by txz033000 » March 9th, 2015, 3:17 pm
Hi, All,
I am trying to use our Keithley 6487 to drive one electronic device, but we got some scum/native oxide at the device interface, therefore at first we need to use a high voltage like 250V to break down this scum/native oxide, in order to get electrical signal to the device.((actually it is the electrical field which break down the scum/native oxide). However, once the scum/native oxide is down, the 250V would be all applied over my device; such a high voltage would generate a current high enough (over 100nA) to burn my device. To protect my device, I would like to set the current compliance of 6487 to around 1nA . In 6487 user manual, it did not say what is the smallest current compliance of 6487 when it outputs 250V. could some shine some light on it?
regards,
tao
brian.d.smith
Re: smallest current compliance of 6487 when output 250V ?
Post by brian.d.smith » March 9th, 2015, 5:42 pm
From the datasheet
SELECTABLE CURRENT LIMIT: 2.5mA, 250μA, 25μA for 50V and 500V ranges, 25mA additional limit for 10V range. All current limits
are –20%/+35% of nominal.
Return to “PicoAmmeters”
