Cannot make a READ? command in Ki-488 - 6487
2502, 6485, 6487 - Support
gabrielachaves
Country: Brazil
Post by gabrielachaves » September 29th, 2015, 11:10 am
Hello everyone,
I'm using a 6487 and a GPIB-to-USB cable (KUSB-488B driver) to read currents in a Windows 8 (I'm going to use Labview). I think the driver is working fine, I can see my - model on Configuration Utility software.
When I start Diagnostic Tool, I can communicate with it, using the standard address, 22. If I put an *IDN? command, it's answer is OK.
However, every reading (READ?, MEASURE?, ...) I try to do after that makes a timeout error.
I also tried
*RST
:INIT
:TRG
as I saw in another topic and it makes a -113 error, "Undefined header", but it seems that's no error in my commands.
Could anyone help me?
Gabriela.
Re: Cannot make a READ? command in Ki-488 - 6487
Post by Dale C » September 29th, 2015, 12:26 pm
On default the ARM COUNT is set to INF.
Try sending the following command.
:ARM:COUNT 1
THen send :READ?
THat should do it.
gabrielachaves
Country: Brazil
Post by gabrielachaves » September 29th, 2015, 1:39 pm
Dale,
it's working, thanks!
Could you please answer one more question?
Whats the difference between Arm Count and Trigger Count?
Thanks in advance,
Gabriela.
Post by Andrea C » September 30th, 2015, 3:50 am
Gabriela,
Check out figure 7-2 in the 6487 Reference Manual. It shows the remote trigger model flow chart.
You can see the effect of arm count and trigger count in that figure.
Return to “PicoAmmeters”
