building a diode voltage clamp
2502, 6485, 6487 - Support
TOKABU
Post by TOKABU » March 31st, 2016, 9:07 am
Hello all,
Long story short we had our Keithley 6485 - (peeco ammeter*) repaired by Keithley and to prevent a future issue they suggested to build a diode voltage clamp to protect the meter.
The email recommends using a 2n3595 or MMBD1503 diodes as they are low leakage diodes. I haven't had such luck finding them (2N3595 doesn't exist) or they are SMD only.
I've found an old pdf from keithley out on the web building one:
https://doc.xdevs.com/doc/Keithley/Over ... tion22.pdf
and they recommended using 1n3595 diodes which are plentiful and cheap. Mouser doesn't say if they are low leakage or not. (see below)
http://www.mouser.com/ProductDetail/Fai ... y1m2LNsIzc
The 2 links below DO say they are low leakage, would they work for this application?
http://www.mouser.com/ProductDetail/Fai ... S3uKPjA%3d
http://www.mouser.com/ProductDetail/NXP ... porary-tag
Any help is appreciated!
**PS forum is censoring the word "Papa India Charlie Oscar" ammeter.....
Re: building a diode voltage clamp
Post by Dale C » March 31st, 2016, 10:24 am
The diodes should be 1N3595. Not 2N3595.
These are low leakage fast reacting diode.
They should do the trick.
TOKABU
Post by TOKABU » March 31st, 2016, 10:55 am
Perfect, thanks!
Return to “PicoAmmeters”
