6485 analog output wrong
2502, 6485, 6487 - Support
khupys
Country: South Korea
Post by khupys » October 30th, 2019, 3:57 am
I am using Keithely 6485 - with +-2V analog output per full scale input.
As the manual says, the output voltage should be between -2 and +2 V, but our measurement shows it is around 3.7 V.
It does change with the reading but only decreases down to around 3.4 V at full scale display at the front panel?
Other functions seem to be working OK.
What could have gone wrong with this 6485?
Any idea ?
Thanks~~!
Modify message
Re: 6485 analog output wrong
Post by Andrea C » November 7th, 2019, 4:23 am
3.7V vs. expected value of 2.0 is quite a large difference. I suspect malfunction in the analog output circuit.
Is it similar for each current range? Each range should be scaling it's full scale value to approximately +/-2V.
For open circuit condition on the Amp meter (0 Amps), what is the AO value then? Does it come close to zero?
Your instrument may need service.
Return to “PicoAmmeters”
