Reading in 2502
2502, 6485, 6487 - Support
irsatc
Country: Poland
Reading in 2502
Post by irsatc » June 6th, 2012, 3:41 am
I am using kiethley 2502 - with labview 2010. I downloaded software drivers for model 2500 from keithley support site, and had them working. However, when i try to measure current on channel 1 the resulting value (~0.40 nA) is displayed only on hardware and i cannot make it visible in labview. Have anyone of you ever tried to work with 2502 and labview?
Thanks inadvance,
Tom
Re: Reading in 2502
Post by Dale C » August 7th, 2012, 7:37 am
Here is a simple sweep VI that uses SCPI commands.
It does not use the driver.
Maybe it will help.
2502SampleSweep.vi
(8.52 KiB) Downloaded 1552 times
zwhwin
Country: China
Re: Reading in 2502
Post by zwhwin » March 30th, 2017, 8:00 pm
hi, irsatc or Tom,
I am looking for the corresponding labview control sub-VIs for kiethley 2502 for a long time! I am so happy when I see the message "reading in 2502" you posted in this forum! So are you convenient to provide a copy of these labview VIs for kiethley 2502 for me? If so, THANK YOU SO MUCH!
zwh
Return to “PicoAmmeters”
