6221 ethernet control with Pyvisa
6220, 6221 Current Sources
F_CHEM_
Country: United Kingdom
Post by F_CHEM_ » March 31st, 2015, 6:37 am
Hello all,
I am looking to set up my 6221 current source to be controlled via ethernet. I can successfully ping the device and validate it's existence using NI-VISA configuration.
I am however unable to control the device using visa commands (via pyvisa wrapper). An example snippet of python code:
import visa
visa.get_instruments_list()
# Does not return keithly connected via ethernet
keithly = visa.instrument('keithly_6221') # currently using pyvisa pre-dating 1.5.. this is the alias I defined in MAX.
keithly.ask('*IDN?')
... And then get a timeout error.
I have read this maybe a problem with termination characters. I am not sure how to use these and could find very little information on them. I have tried sending various strings:
keithly.ask('*IDN?\n')
keithly.ask('*IDN?<CR>') and so on..
But to no avail.
If anyone has any experience with this your help would be much appreciated.
EDIT:
Using the VISA test panel I can successfully write '*IDN?\r' to the instrument and then read it. But the same command does not work using python.
Re: 6221 ethernet control with Pyvisa
Post by Andrea C » March 31st, 2015, 1:50 pm
Assuming IP address of instrument is 10.10.10.10, try this:
keithly = visa.instrument("TCPIP::10.10.10.10::1394::SOCKET")
keithley.term_chars = "\n"
keithley.ask("*IDN?")
Modify for your IP address.
F_CHEM_
Post by F_CHEM_ » April 1st, 2015, 12:56 pm
Brilliant thanks - this worked!
Could of sworn I tried this but must of used a different termination character!
Return to “Current Sources”
