6221 harmonics
6220, 6221 Current Sources
ALucente
6221 harmonics
Post by ALucente » April 10th, 2015, 8:37 am
I'm using a model 6221 as an AC current source in a test setup that monitors the system's third harmonic response to a sine wave through a lock-in amplifier. The current source does not seem to supply a clean enough signal for this application. If I apply a current of 10 mA (RMS) to a 25 ohm resistor, there appears to be about 1.7uA of current being supplied at the third harmonic. Is that within specification limits or does the instrument need recalibration?
brian.d.smith
Re: 6221 harmonics
Post by brian.d.smith » April 10th, 2015, 7:15 pm
It appears that there is not a spec for THD nor particular harmonic content.
Return to “Current Sources”
