Cant detect 6221
6220, 6221 Current Sources
[email protected]
Country: Singapore
Cant detect 6221
Post by [email protected] » November 21st, 2016, 7:17 pm
Hi, i am trying to use Labview to command my current supply.
6221 is connected to my pc using ethernet.
I set my computer ip to static with same subnet and gateway as the settings in my 6221
i am able to ping my instrument's set ip add.
But labview MAX is unable to detect 6221.
When i manually change the visa address in the example in labview to
TCPI::192.168.0.20::1394::SOCKET or TCPI::192.168.0.20::1394::INSTR
it also didnt work.
Any idea why?
[email protected]
Country: Singapore
Re: Cant detect 6221
Post by [email protected] » November 21st, 2016, 9:58 pm
Sorry managed to solved the issue after using the correct subnet mask class. :D
Return to “Current Sources”
