SCPI & 6621
6220, 6221 Current Sources
angelo
Country: Brazil
SCPI & 6621
Post by angelo » January 9th, 2017, 11:53 am
Guys, can someone tell me what is wrong for this situation below ?
if I send "SOUR:WAVE:FUNC SIN" it is ok
if I send "SOUR:WAVE:FREQ 227" it is ok
but if I send "SOUR:WAVE:FUNC SIN;SOUR:WAVE:FREQ 227" I got an error -113
angelo
Country: Brazil
Re: SCPI & 6621
Post by angelo » January 9th, 2017, 12:14 pm
The same I have for:
"SOUR:WAVE:DUR:TIME INF;SOUR:WAVE:RANG BEST" I got error -113
"SOUR:WAVE:DUR:TIME INF" is OK
"SOUR:WAVE:RANG BEST" is OK
Kenneth P
Re: SCPI & 6621
Post by Kenneth P » January 12th, 2017, 10:02 am
I'm not sure what the issue may be. I checked the LabVIEW driver for the 6221 and found numerous line sends where multiple commands are concatenated using a semi-colon.
If you happen to be using the National instruments VISA DLL in your code, I suggest that you use NI I/O Trace to determine if all the code is being sent.
Tad Bak
Country: Australia
Re: SCPI & 6621
Post by Tad Bak » January 25th, 2017, 3:54 am
I had a similar problem with different instructions. In my case I have solved it by adding a colon after semicolon. Please try:
"SOUR:WAVE:FUNC SIN;:SOUR:WAVE:FREQ 227"
Hope this helps.
Return to “Current Sources”
