Failed while upgrading 6221 D01 firmware to D03
6220, 6221 Current Sources
Huskie
Country: China
Post by Huskie » November 20th, 2017, 12:53 am
I used the Flash Wizard32 C12 to upgrade 6221 through ethernet, but when the progress bar went to 8%, the software showed an error message that the connection broke off. Then it showed the upgrading failed. I tried to reboot 6221, but it desplays "Fpga CHKSUM" after initializing. And the software can't connect to 6221 anymore.
So how can I save the 6221, is there something like recovery mod that I can download the firmware in to 6221?
keithleyuse
Re: Failed while upgrading 6221 D01 firmware to D03
Post by keithleyuse » November 20th, 2018, 3:26 pm
I am having the same problem. Did you ever find a solution?
Return to “Current Sources”
