We are trying to do a delta measurement with very low currents (on the 1 to 100 nanoamp range). We set up a Labview code (attached below) for this purpose and it should be working for any current between 10^-9 amp to 10^-6 amp, but it doesn't.
First of all, when we try to run the delta mode using 10^-6 amp current with 2*10^-6 amp range it works perfectly. However if we run it with 10^-7 amp (with 2*10^-7 amp range), 10^-8 amp (with 2*10^-8 amp range) and 10^-9 amp (with 2*10^-9 amp range) it doesn't work at all. We used auto range and it failed. We tried to write our own autorange code and it also failed (see the disabled part). Then we just manually entered the range, but 6221 seems to ignore our command to adjust the range whatever we do. Strangely enough, When we open Instrument Assistant I/O and run the CURR:RANG x manually, it works like magic for every current from 10^-9 amp to 10^-6 amp!
Can you explain why 6221 ignores our commands to adjust the range?
Thank you.
6221/2182A Delta Mode - Current Range Commands Ignored by 6221
6220, 6221 Current Sources
- Country: Turkey
Post by ozgurrustem » August 14th, 2018, 2:38 am
- Attachments
- delta_test.vi
- (432.51 KiB) Downloaded 236 times
Jump to
- Announcements
- Customer Support
- ↳ Product Support
- ↳ Oscilloscopes
- ↳ Programming Support
- ↳ Passive/Low Voltage
- ↳ High Voltage
- ↳ Differential
- ↳ Current
- ↳ Signal Sources
- ↳ AFG1000/2000/3000 series
- ↳ AWG5000/7000/70000 Series
- ↳ Keithley 3390
- ↳ TSG4100A Series
- ↳ Spectrum Analyzers
- ↳ Announcements and FAQs
- ↳ RSA Programming
- ↳ RSA5000/6000 Series
- ↳ Vector Network Analyzers
- ↳ TTR500 Series VNAs
- ↳ 2600 Series SourceMeter
- ↳ 2400 Series SourceMeter
- ↳ DMM6500 Bench/System DMM
- ↳ Other DMM's
- ↳ 7000 Series Switch
- ↳ 700 Series Switch
- ↳ RF Switch
- ↳ Other Switches
- ↳ Power Supplies
- ↳ Series 2300
- ↳ Other Power Supplies
- ↳ Power Analyzers
- ↳ ACS Software Products
- ↳ Nanovoltmeters
- ↳ Electrometers
- ↳ Curent Amplifiers
- ↳ PicoAmmeters
- ↳ Current Sources
- ↳ Bit Error Rate Testers
- ↳ Logic Analyzers
- ↳ Video Test
- ↳ Other Instruments
- ↳ Electronic Loads
- ↳ Frequency Counters
- ↳ Software
- ↳ TekScope Anywhere
- ↳ SourceXpress
- ↳ SignalVu-PC
- ↳ PWRVIEW
- ↳ KickStart
- ↳ Test Script Builder
- ↳ LabView Drivers
- ↳ IVI Drivers
- ↳ TekVISA
- ↳ ExcelLINX
- ↳ IVy
- ↳ Keithley I/O Layer (KIOL)
- ↳ Accessories
- ↳ Test Fixtures
- ↳ Cables and Connectors
- ↳ Application Support
- ↳ Low Current Measurements
- ↳ Low Voltage Measurements
- ↳ Resistivity Measurements
- ↳ Hall Measurements
- ↳ Electrochemistry
- ↳ Solar Cell Measurements
- ↳ High Brightness LEDs
- ↳ General Discussion
