6221/2182A LabView examples are not working
6220, 6221 Current Sources
steve_bmw
Post by steve_bmw » September 27th, 2018, 2:54 am
I have a problem with the 6221/2182A in combination. We are trying to start a delta measurement with the delta measurement example from the Keithley library. I´ve downloaded it from the Keithley homepage. The execute delta measurement VI isn´t working.
I´ve already found one mistake in the "Reset.vi". I´ve configured the ethernet connection, which one now is working.
Has anybody an idea, what the problem is?
Thank you in advance
KE622x -- Delta Meas Example.vi
(49.7 KiB) Downloaded 641 times
Return to “Current Sources”
