command for setting the range of waveform amplitude
6220, 6221 Current Sources
hachiko
Country: China
Post by hachiko » October 14th, 2018, 9:30 pm
On the 6221 manual, I could not find the command for setting the range of waveform amplitude.
How can I select a range for the waveform amplitude remotely? Have to manually do this?
PS: the common range command ":SOUR:CURR:RANG 2E-6" does not work on waveform.
WT
Return to “Current Sources”
