6221 with lock-in amplifier
6220, 6221 Current Sources
dmccann
Country: United Kingdom
Re: 6221 with lock-in amplifier
Post by dmccann » May 21st, 2015, 1:36 am
Dale C wrote:That is correct.
The phase maker pulse is normally +5V.
When it outputs a pulse, it goes to 0V for the 1usec then back up to 5V.
So because the pulse is a drop of 5V to 0V then it is correct to use 'Neg Edge' option for detecting this pulse on the lock-in then?
Return to “Current Sources”
