7011 sequencal switching
7001, 7002 and Switch Cards
olorin17
Post by olorin17 » May 29th, 2014, 4:13 pm
Hello everyone! I am trying to get the Keithley 7001, with a 7011c card to open and close channels in sequence. I.E. close @1!1, open @1!1, close @1!2, open @1!2, but in sequence, NOT all at once. I am able to open and channels with the SCPI commands individually, but i need it to operate all as one big program. can anyone give me a hand? i am not even sure where to start.
thanks in advance!
Re: 7011 sequencal switching
Post by Dale C » May 30th, 2014, 5:58 am
What you are referring to is a "scan".
Simply set up a scan list with the following command.
:ROUTE:SCAN (@1!1:1!40)
Then set up the trigger count for the number of channels.
:TRIGGER:COUNT 40
This will go through all 40 channels one time when the appropriate trigger is received.
