Switch System Losing All Memory Every Time It is Turned Off
7001, 7002 and Switch Cards
melegaunt
Post by melegaunt » March 19th, 2015, 1:27 pm
Hello there,
I have a 7001 Switch System with a 7065 Hall card and a 7012 card in it.
I have programed a dozen memory settings into the machine and saved the system setup as Save 1 in the Menu/Save settings so that it can be restored.
Unfortunately any time I power down this machine it loses everything that has been put into it, as I soon discover the following day when it is powered back on.
It did not always do this and has only started this in the past few days. No hardware or settings were changed when it began. Everything was the same as always.
Does any one have any idea why I would be losing all of my saved settings like this and what I could do to fix it?
Thank you!
Re: Switch System Losing All Memory Every Time It is Turned
Post by Andrea C » March 19th, 2015, 2:24 pm
Sounds like the battery needs replacement.
See section 7.4.3 Changing the battery, in the model 7001 Switch System Instruction Manual.
