Upgrading the firmware for Keithley 7001
7001, 7002 and Switch Cards
RogerioHein
Country: Brazil
Post by RogerioHein » June 15th, 2017, 3:50 pm
Hi!
How is the procedure to update the 7001 firmware? Could you send me the latest version? My unit is presenting errors associated to digital board, and the manual says that these errors can be related to firmware version...
Thanks in advance!
mgross
Re: Upgrading the firmware for Keithley 7001
Post by mgross » September 20th, 2017, 7:19 am
the procedure is described in the 7001 Instruction Manual (7001-901-01H.pdf, Page 270). You must burn a EPROM, the EPROM file. The Hexfile can you found at https://doc.xdevs.com/article/keithley-instruments/.
Greetings
Matthias
