Multiple Channel Operation
7001, 7002 and Switch Cards
brent_shen
Country: Canada
Post by brent_shen » March 9th, 2011, 8:29 am
Hi Dale,
Assume that 7708 is installed in slot 1 of 2701. If I type the following command,
1) ROUT:OPEN:ALL
2) ROUT:MULT:CLOS (@102,145)
3) ROUT:CLOS (@101)
Then, is channel 102 automatically open? or both channels 101 and 102 are closed?
Many Thanks
Brent Shen
Nathan S
Re: Multiple Channel Operation
Post by Nathan S » March 9th, 2011, 10:16 am
Brent,
When issuing the ROUT:CLOS (@101) in line 3, channel 101 is closed and all others are opened including the ones previous closed in line 2. You can verify this using the ROUT:CLOS? command after line 3.
I hope this helps.
Nathan
