122: Device Settling
7001, 7002 and Switch Cards
Veloxer
Post by Veloxer » May 5th, 2011, 2:13 pm
Hello, I'm using a 7002 switch system with a 7011-C Quad 1x10 multiplier and run into a status event "122: Device Settling" between each measurement. Will this affect my measurements and how can I resolve this SE?
Kierthi
Re: 122: Device Settling
Post by Dale C » May 6th, 2011, 5:30 am
The only place I see "Settling" is in the Operation Condition Register. This is bit 2.
What this means is the relay is settling from a close command.
What is the TRIGGER:DELAY set to? On default it is 0.0 seconds. Maybe with the 122 status it is set much longer.
