Model 7158 card is not detected in 7001
7001, 7002 and Switch Cards
pevans
Post by pevans » June 14th, 2010, 10:23 am
I have a Model 7158 low current scanner card installed in the Model 7001 scanner.
The card is not recognized by the 7001.
What is wrong?
Re: Model 7158 card is not detected in 7001
Post by Dale C » June 14th, 2010, 10:38 am
There are several older cards that are not recognized by the 7001 upon power up.
The Model 7001 needs to be informed these cards are installed.
Use the CARD button, select the slot number and use the right/left arrow keys to enter the card.
Or use the SCPI command :ROUTE:CONFIGURE:SLOTX:CTYPE (:ROUTE:SLOT1:CTYPE C7052)
The following cards are not recognized upon power up:
* 7052 4x5 Matrix card
* 7053 High Current card
* 7054 High Voltage card
* 7056 General Purpose card
* 7057A and 7402 Thermocouple cards
* 7058 Low Current card
* 7059 Low Voltage card
* 7061 Universal Adapter card
* 7062 and 7063 RF Switch cards
* 7064 20 channel low voltage card
* 7066 Relay Switch card
* 7067 4-Wire card
* 7152 Low Current 4x5 Matrix card
* 7153 High Voltage Low current matrix card
* 7154 High Voltage card
* 7156-D and 7156-M general purpose cards
* 7158 Low Current card
* 7159 Low Voltage Card
* 7164-D and 7164-M 20 channel cards
* 7166 Mercury Wetted card
* 7168 NanoVolt card
* 7169A 20 Channel Form C card
