7002 wiring harness accessory
7001, 7002 and Switch Cards
JDAdams
Post by JDAdams » January 5th, 2011, 1:37 pm
We have one of your 7002 switch matrixes and a high-density harness that is used with it. We would like to use it in a temperature testing application where the temperature could potentially be as high as 200 degrees C. Would the the standard harnesses be able to withstand this temperature? If not, do you have a stock solution for this application, or could you recommend a company that does?
Waiting for your answer, thanks.
Jim Adams
Biotronik (Micro Systems Engineering)
[email protected]
503 744 8743
Re: 7002 wiring harness accessory
Post by Dale C » January 5th, 2011, 1:41 pm
Hello Jim,
Could you tell what Model number the wring harness is?
With that I might be able to look up the specs.
JDAdams
Post by JDAdams » January 6th, 2011, 10:04 am
Yes, on one side of the connector, it has:
7011-314-1
1 meter
Rev A3
May 0846
And on the other side it says:
7011-MTC-1
Post by Dale C » January 6th, 2011, 10:54 am
The entire cable which is Keithley part number 7011-MTC-1 is made of of several components and is rated from 0Cto 50C.
This means that all of the components can be used up to 50C.
Maybe the cable can handle higher temperatures, of this I am not sure.
The cable is from Hitachi with a part number #48343-50.
Maybe Hitachi has more detailed specs
