7011-C Issue with new card
7001, 7002 and Switch Cards
ericand
Post by ericand » February 27th, 2014, 3:24 pm
I have a 7002 switch with 7011-C and 7035 cards that was built many years ago. Recently, I duplicated this system with all new hardware. However, the voltage levels in my system are not correct. When I swap the new 7011-C cards out with the old ones, the new system works correctly. In the same way, placing the new 7011-C cards in the old system duplicates the problem. Has the design of the 7011-C card changed? Or is there some required configuration of the card that I'm not aware of?
Thank you
Re: 7011-C Issue with new card
Post by Dale C » February 28th, 2014, 7:27 am
Hi Eric,
Can you define what you mean by th voltage levels are not correct?
Is this the signal being routed through the 7011-C card?
Or is it the relay drive voltage on the card?
