Automate PA1000 with Python
PA1000, PA3000, PA4000
[email protected]
Post by [email protected] » February 23rd, 2018, 5:12 pm
I am having an issue with reading data from PA1000.
I have done the following:
1. Installed NI VISA
2. Installed Python 2.7
3. Installed PyVISA Library Version 1.5
4. Wrote the following test program
import visa
rm = visa.ResourceManager()
print rm.list_resources()
inst = rm.get_instrument('GPIB0::6::INSTR')
inst.write("*IDN?"+"\n")
print inst.read(":FRD?"+"\n")
I am seeing the following error every time I execute the above commands
pyvisa.errors.VisaIOError: VI_ERROR_TMO (-1073807339): Timeout expired before operation completed.
Executing *IDN? on VISA Test Panel gives the Following
Write Operation (*IDN?)
Return Count: 5 bytes
2: Read Operation
Return Count: 36 bytes
Tektronix,PA1000,B010273,Ver.1.3.15\n
GUSTAVO
Country: Brazil
Re: Automate PA1000 with Python
Post by GUSTAVO » April 20th, 2018, 10:14 am
You should insert those lines in your code when working with PA1000:
analyzer.read_termination = '\n'
analyzer.write_termination = '\n'
inst.write("*IDN?"+"\n") doesn't work in this case.
NI MAX write/read the messages of that instrument with those terminations automatically (*IDN?\n).
Return to “Power Analyzers”
