This Web Forum has moved to TekTalk! Please join us to find support answers and connect with the Tek community!
TektronixToolBarsSetup Installation Problem
DPO70000SX, DPO/MSO70000, DPO7000 Series, DPO/MSO5000 Series
yctek101
Country: Malaysia
Post by yctek101 » November 24th, 2016, 1:52 am
I have installed OpenChoice TekVISA v4.1.1.15. When I want to install TektronixToolBarsSetup.exe, I received an error message "Please install OpenChoice TekVISA before running this installation. Setup will abort now."
Please help. Thanks.
Re: TektronixToolBarsSetup Installation Problem
Post by David N » November 28th, 2016, 9:46 am
Per chance are you using Office 64-bit? The toolbar only works with Office 32-bit.
tekuser
Post by tekuser » September 19th, 2017, 2:37 am
I am using 32-Bit Office and got the same message?
Post by David N » September 19th, 2017, 9:53 am
The issue is that the Excel tool bar requires a 32 bit Tek Visa and the current Tek Visa on Tek.com is only for 64 bit OS. At this time we do not have a working solution for the Excel tool bar.
stevenkanPRL
Post by stevenkanPRL » June 25th, 2020, 12:13 am
Hi David,
Any progress on this? The Tek toolbar was a terrific feature!!!
mmalisorn
Post by mmalisorn » December 2nd, 2021, 3:15 pm
The add-in work ok. Installed on Excel2013 and Excel 2019 (32 bits). You must use TEKVISA CONNECTIVITY SOFTWARE, V4.0.4. I also install Openchoice Desktop and the program also work.
stevenkanPRL
Post by stevenkanPRL » May 8th, 2023, 10:48 am
Hi all,
After many years of struggling with this, I have finally figured out the solution to getting the TekVisa Toolbars for Office running on modern systems.
Short version:
  1. Install the 32-bit versions of Microsoft Office, TekVISA, and the TekVISA Toolbars
  2. Manually copy the toolbar template files to %OFFICEROOT%\startup and \xlstart
  3. Add those directories as Trusted Locations to the Office Trust Center
Long version, with step-by-step directions and links:
https://www.pulseresearchlab.com/pages/ ... fice-win64
Please let us know if this helps!
Return to “Windows Based Oscilloscopes”
