Digital Serial Analyzer Sampling Oscilloscope DSA8200
Azam AlRawachy
Country: United Kingdom
Post by Azam AlRawachy » October 4th, 2018, 12:26 pm
I have NI measurement system consist of two chassis VSA & VSG to generate and acquiring the signals. I have connected Oscilloscope DSA8200 to measure the time domain waveform and to check them with the generated waveform from NI receiver system. I started with generating two tones (as per attached ( 1 GHz and 1.001 GHz) while the 10 MHz timing is connected with VSA & VSG to be synchronized and the trigger is connected as an external trigger.
I am just wondering if this Oscilloscope is capable of reading these waveform and it is right as shown in attached thread or something else is needed because I am unable to get the waveform from the scope and the NI receiver to be matched. Thanks in advance.
