Save HardCopy to PC by vba
dkq2315
Country: China
Post by dkq2315 » July 28th, 2020, 6:52 am
I am trying to control my scope using MS Excel VBA.save wave file to my pc.
Following is the VB code which I am having trouble fixing.
Option Explicit
Public id As Integer 'session to instrument
Public Const bytearraysize = 1000000
Public retcount As Long
Public bytearray(bytearraysize) As Byte
Public idn, idos, idac, idlda, idldb, idldc As String
Public rm As VisaComLib.ResourceManager
Public fmio As New VisaComLib.FormattedIO488
Private Declare Sub sleep Lib "kernel32" (ByVal dwmilliseconds As Long)
Public AppSheet As Worksheet
Public strQueryResult As String
'save wave
Sub hcopy()
Dim DoCommand As String
Set AppSheet = ThisWorkbook.Sheets("Sheet1")
Set rm = New VisaComLib.ResourceManager
idos = AppSheet.Cells(1, 2) 'OSC address
Set fmio.IO = rm.Open(idos)
fmio.IO.Timeout = 500 '延时
fmio.IO.Clear
Dim byteData() As Byte
DoCommand = ":HARDCOPY START"
fmio.WriteString (DoCommand)
' byteData = DoQueryIEEEBlock_UI1(":DISPlay:DATA? PNG,COLor")
'save screen image to a file.
Dim insize As Long
insize = 2
Dim strPath As String
strPath = "e:\screen12.png"
If Len(Dir(strPath)) Then
Kill strPath
End If
Dim hFile As Long
hFile = FreeFile
Open strPath For Binary Access Write Lock Write As hFile
Dim longi As Long
'For longi = 0 To insize - 1
Put hFile, , byteData
' Next longi
Close hFile
End Sub
Private Function DoQueryIEEEBlock_UI1(query As String) As Variant
'On Error GoTo VisaComError
fmio.WriteString query
DoQueryIEEEBlock_UI1 = fmio.ReadIEEEBlock(BinaryType_UI1)
'CheckInstrumentErrors
Exit Function
'VisaComError:
End Function
The saved wave file is 0 bytes,where is the problem? can someone help me? thank you very much!
