Acquire data with KUSB 3108 on windows 8
Jamal_IE
Country: Ireland
Post by Jamal_IE » September 15th, 2014, 10:28 pm
I want to inquire about the compatibility of KUSB 3108 windows 8. Can I use dtlvlink drivers to develop applications into Labview 2013?
Regards
Re: Acquire data with KUSB 3108 on windows 8
Post by Dale C » September 17th, 2014, 6:18 am
Are you able to install and use your CD/drivers on a Windows 7 system? If so, then it should work on a Windows 8 system. Have you tested the installation on a Windows 8 system? If successful, then you should be able to use the DTLvLink with LabVIEW 2013.
Now we haven't updated your CD in awhile, but if the CD installation worked, then there's a good chance you can develop under LabVIEW 2013. If after testing, you are unsuccessful, then the fallback might be to install our latest LV-Link installation.
Jamal_IE
Country: Ireland
Post by Jamal_IE » September 17th, 2014, 11:37 am
I have tried to install on windows 8 but drivers are not installed however quickdaq application is installed but does not work properly. is there any compatibility of CD revision J with windows 7 64 bit? and could you please provide link for latest LV-LINK drivers for 64 bit Labview 2013?
Also, the application examples of LV-LINK do not work on labview 2010 on windows xp with kusb-3108. Could you please provide its solution?
Regards
Post by Dale C » September 17th, 2014, 12:17 pm
From what I can see, the Keithley CD has not been updated in some time.
Therefore, you have the following options:
- Install the Keithley OMNI CD on a Windows 8, 32-bit system
- Install the Keithley OMNI CD on a Windows 7, 64-bit system
- Install the DT DataAcq OMNI CD and latest LV-Link download on a Windows 8 system
The last one is available from Data Translation at this link.
http://www.datatranslation.com/
Jamal_IE
Country: Ireland
Post by Jamal_IE » September 18th, 2014, 9:18 am
we purchased kusb-3108 data logger around 6 years ago, could you please let me know the source from where i can get Keithley OMNI CD for Windows 7, 64-bit system?
Regards
Post by Dale C » September 18th, 2014, 1:19 pm
