MDO4054C: SPI bus event table?
vadim.b
Country: Belgium
Post by vadim.b » May 13th, 2020, 9:11 am
I am debugging the transfers over SPI bus. The settings are:
  • Framing: SS
  • Trigger on: SS Active
The MCU exchanges 5 frames with the device (SS is active 5 times):
The first two frames, zoomed in, look like this:
But the event table shows only one event, which is all the data transferred in all 5 frames:
Is it possible to see 5 events in the event table?
Am I missing something? I have read the relevant sections of the User Manual and have searched this forum. Couldn't find the answer.
The scope is MDO4054C, firmware v1.08.
Kind regards,
Vadim
vadim.b
Country: Belgium
Re: MDO4054C: SPI bus event table?
Post by vadim.b » June 8th, 2020, 4:55 am
ping tek.com
w2aew
Post by w2aew » June 8th, 2020, 7:41 am
Double check your bus setup and the threshold settings for the SS line. You can see the start of frame which is the green [ symbol, but the end of frame should show up as a red ] symbol. This is not shown with makes me think that maybe the threshold isn't set correctly.
vadim.b
Country: Belgium
Post by vadim.b » June 9th, 2020, 7:23 am
Yep, that was it! Thank you for the hint.
SS threshold was on par with that of MOSI and MISO, but way too high for frame end detection.
Kind regards,
Vadim B
