AFG3201B TekVisa API Question
alani
Post by alani » September 30th, 2013, 11:06 am
Hi Support,
This is in regards to AFG3201B.
In the example code manual there is :
        'Set CH1 output parameters
        Tvc1.WriteString("FUNCTION SIN") 'Set output waveform SIN
        Tvc1.WriteString("FREQUENCY 10E3") 'Set frequency 10kHz
        Tvc1.WriteString("VOLTAGE:AMPLITUDE 2.00") 'Set amplitude 2Vpp
        Tvc1.WriteString("VOLTAGE:OFFSET 1.00") 'Set offset 1V
        Tvc1.WriteString("PHASE:ADJUST 0DEG") 'Set phase 0degree
but in the commands you have to do for example:
SOURce1:PWM:INTernal:FREQuency 10kHz
One states the SOURce, but the other does not. How does this work?
alani
Re: AFG3201B TekVisa API Question
Post by alani » September 30th, 2013, 11:26 am
Update here is my VB code:
        'Assign resource
        Tvc1.Descriptor = "GPIB0::11::INSTR"
        'Initialize of device setting
        Tvc1.WriteString("*RST")
        Tvc1.WriteString("SOURce1:PULSe:DYCLe 50")                   'Sets the duty cycle to 50%
        Tvc1.WriteString("SOURce1:PULSe:TRANsition:LEADing 200ns")   'Sets the leading (rise time) to 200ns
        Tvc1.WriteString("SOURce1:PULSe:TRANsition:TRAiling 200ns")  'Sets the trailing (falling time) to 200ns
        Tvc1.WriteString("SOURce1:PULSe:PERiod 200ns")               'Sets the Period to 200ns
        Tvc1.WriteString("SOURce1:VOLTage:LIMit:HIGH 100mV")         'Sets Low Level to 100mV
        Tvc1.WriteString("SOURce1:VOLTage:LIMit:LOW 100mV")          'Sets High Level to 100mV
        'Save settings and output on
        Tvc1.WriteString("*SAV 1") 'Save settings to Setup1
        Tvc1.WriteString("*RCL 1") 'Recall settings from Setup1
Question:
I have installed TekVisa (400meg) installation file, is that all I will need to communicate to the GPIB? or is there other drivers/software I need to install
ashinde
Post by ashinde » March 27th, 2014, 11:26 pm
http://www.tek.com/signal-generator/afg ... 0-series-0
programmer manual for remote controlling.
Regards,
Abhijeet
