% Date: 6/16/14
% Tested on a 64-bit Windows 7 computer
% using TekVISA 4.0.0 and Matlab 2013a
% with the Matlab Instrument Control Toolbox
% Program: AFG3000 Dual Channel Arb Waveform Load and Output
% This program configures amplitude and frequency for both channels,
% loads two separate waveforms into the AFG, and outputs them
% on Channel 1 and Channel 2, respectively.
%% Set up TekVISA
% Specify VISA brand, instrument address, and buffer. Open instrument
visa_brand = 'tek';
visa_address = 'USB::0x0699::0x0345::C010255::INSTR';
buffer = 50 * 1024;
instrument = visa(visa_brand,visa_address,'InputBuffer',buffer,...
'OutputBuffer',buffer);
fopen(instrument);
% Define waveform file names, note the inclusion of double-quotes
% INSIDE the string
%Waveform name includes # of points for the sake of clarity
wfm1name = '"Cardiac_10k.TFW"';
wfm2name = '"Sinc_10k.TFW"';
ID = query(instrument,'*IDN?'); %Query instrument identifier.
disp(ID); %Display instrument identifier
fwrite(instrument,'*RST'); %Reset the instrument
%% Set up amplitude and frequency
fwrite(instrument,'source1:frequency 5e5'); %Set channel 1 to output 500 kHz
fwrite(instrument,'source1:voltage:level:immediate:amplitude 2'); %Set channel 1 amplitude to 2Vpp
fwrite(instrument,'source2:frequency 1e6'); %Set channel 2 to output 1 MHz
fwrite(instrument,'source2:voltage:level:immediate:low -1'); %Set channel 2 high level at 1V
fwrite(instrument,'source2:voltage:level:immediate:high 1'); %Set channel 2 low level at -1V
%% Load TFW files into channels 1 and 2
% Since there is only one memory location into which a user can load a
% waveform, it is necessary to copy each waveform into a separate memory
% location in order to avoid overwriting the first waveform with the second
fprintf(instrument,'mmemory:load:trace ememory, %s', wfm1name); %Load the waveform file into ememory
fwrite(instrument,'data:copy user1, ememory'); %Copy the waveform from ememory into User1
fwrite(instrument,'source1:function user1'); %Assign the waveform in User1 to Channel 1
fprintf(instrument,'mmemory:load:trace ememory, %s', wfm2name); %Load the waveform file into ememory
fwrite(instrument,'data:copy user2, ememory'); %Copy the waveform from ememory into User2
fwrite(instrument,'source2:function user2'); %Assign the waveform in User2 to Channel 2
fwrite(instrument,'output1:state on'); %Turn on Channel 1 output
fwrite(instrument,'output2:state on'); %Turn on Channel 2 output
%% Disconnect from and close instrument
fclose(instrument);
delete(instrument);
clear instrument;
