AFG3000 Python Load and Output 2 Separate Waveforms
tekzilla
Post by tekzilla » June 17th, 2014, 10:11 am
This code loads two separate waveforms from a USB flash drive into the AFG and then outputs them. There is only one memory location (ememory) into which the user can load a waveform, so in order to avoid overwriting the first waveform with the second, it is necessary to save each waveform into separate intermediate memory locations before outputting them to each channel.
The two waveforms were made using ArbExpress in .TFW format and are located in the top directory of the flash drive. ArbExpress can be downloaded here: http://www.tek.com/signal-generator/afg ... 1-software
# Date: 6/17/14
# Tested on a 64-bit Windows 7 computer
# using TekVISA 4.0.0 and Python 2.7.6 with PyVISA 1.5
# Program: AFG3000 Dual Channel Arb Waveform Load and Output
# This program configures amplitude and frequency for both channels,
# loads two separate waveforms into the AFG, and outputs them
# on Channel 1 and Channel 2, respectively.
import visa
instrument = visa.instrument('USB::0x0699::0x0345::C010255::INSTR')
#Waveform name includes number of points for the sake of clarity
#Note the inclusion of double-quotes within the string
wfm1name = '\"Cardiac_10k.tfw\"'
wfm2name = '\"Sinc_10k.tfw\"'
ID = instrument.ask('*IDN?')    #Query instrument identifier.
print(ID)                       #Display instrument identifier
instrument.write('*RST')        #Reset the instrument
# Set up amplitude and frequency
instrument.write('source1:frequency 5e5')                         #Set channel 1 to output 500 kHz
instrument.write('source1:voltage:level:amplitude 2')   #Set channel 1 amplitude to 2Vpp
instrument.write('source2:frequency 1e6')                         #Set channel 2 to output 1 MHz
instrument.write('source2:voltage:level:low -1')        #Set channel 2 high level at 1V
instrument.write('source2:voltage:level:high 1')        #Set channel 2 low level at -1V
# Load TFW files into channels 1 and 2
# Since there is only one memory location into which a user can load a
# waveform, it is necessary to copy each waveform into a separate memory
# location in order to avoid overwriting the first waveform with the second
instrument.write('mmemory:load:trace ememory, {0}'.format(wfm1name))    #Load the waveform file into ememory
instrument.write('data:copy user1, ememory')                #Copy the waveform from ememory into User1
instrument.write('source1:function user1')                  #Assign the waveform in User1 to Channel 1
instrument.write('mmemory:load:trace ememory, {0}'.format(wfm2name))    #Load the waveform file into ememory
instrument.write('data:copy user2, ememory')                #Copy the waveform from ememory into User2
instrument.write('source2:function user2')                  #Assign the waveform in User2 to Channel 2
instrument.write('output1:state on')          #Turn on Channel 1 output
instrument.write('output2:state on')          #Turn on Channel 2 output
