AFG3022C CH1 as trigger for CH2?
sxtysvn
Post by sxtysvn » April 5th, 2015, 12:01 pm
Is it possible to use a channel one waveform to trigger a channel 2 waveform? I am triggering channel 1 (1kHz square wave) externally through the TTL but i want the channel 2 waveform (0.5Mhz) to burst at the channel 1 frequency. Is this possible on this device? Thanks for any help.
Re: AFG3022C CH1 as trigger for CH2?
Post by David N » April 6th, 2015, 4:59 pm
The AFG3022C does not have separate trigger ability between CH1 and CH2. They both use the same trigger event. You could use a second AFG and use the trigger out from the first AFG (CH1) to trigger the second AFG (CH2).
Carl M
Post by Carl M » May 4th, 2015, 1:05 pm
it is odd but if you set ch1 to continuous and ch2 to burst w/ external trigger, yes, you can use ch1 to trigger ch2.
alternatively, you can set a delay from trigger if you just need ch2 to do something later than ch1.
