AFG3102 trigger interval via GPIB
SamiKotijarvi
Post by SamiKotijarvi » May 20th, 2015, 11:42 pm
Hi All,
Does anyone know whether you can control the trigger interval of the AFG3102 thru GPIB? I tried to find that command from the programmer manual, but did not find it there.
The waveform is pulse, in burst mode. You can control the trigger interval by hand by pushing the burst, more and selecting the trigger interval.
Sami
Re: AFG3102 trigger interval via GPIB
Post by David N » May 21st, 2015, 11:55 am
The command you are looking for is: TRIGger[:SEQuence]:TIMer. For the AFG3102, the [SEQuence] portion of the command is not needed.
SamiKotijarvi
Post by SamiKotijarvi » June 1st, 2015, 5:56 am
Thank you Hiker,
I will be testing this. I guess I did not notice this command.
Best regards,
Sami
