ARB Express will not write to AFG1022
shadychris
Post by shadychris » June 25th, 2015, 9:58 am
Hi, We have just taken delivery of new AFG1022's for our student labs
The Data sheet for the AFG1022 stated that "ArbExpress makes user defined waveforms editing extremely easy” which led us to believe that it would be possible to create a waveform in ARB Express and then upload it to the AFG1022.
However whilst the AFG1022 is correctly identified as connected in the main window of ARB Express, when we try to select an instrument to write to in the waveform setup we do not find the AFG1022 model listed amongst the many other model options available. Attempting to select a different instrument such as say the AFG3022 simply results in an error message stating that the selected instrument is not the same as the connected device. So does anyone know if the AFG 1022 can actually be programmed by ARB Express?? Are we missing some patch to the software that will add the AFG1022 to the list of available instruments??
We have also noticed that if we create a waveform in ARB Express and save it, that 2 files are generated..... which one of these should be selected to be sent to the AFG?
shadychris
Re: ARB Express will not write to AFG1022
Post by shadychris » June 26th, 2015, 1:24 am
Having looked at this further I'm beginning to doubt that it is possible to load waveforms generated in ARB Express to the AFG 1022 via the USB link port. From what I can gather the USB uplink port is solely for the use of controlling\programming the device using SCPI commands - something we have no interest in doing.
The data sheet for the 1022 does say ""Compatible with ArbExpress, the user-defined arbitrary waveforms generated by the free software can be loaded on the AFG1022 easily with a USB memory stick."
So I have tried to do that. I can see my USB memory device on the 1022 screen and see the waveform file that is on it. Selecting the 'callout' oprtion - the only one available, I get a message with an exclamation mark saying the file has been successfully read - but I cant then find any way to actually get that waveform displayed on the screen. I suspect that the reason for this is because there is no option to save the waveform in ARB as an AFG1022 compatible waveform. It seems to select the AFG 3012 by default. The User manual is of absolutely no use whatsoever as there is no mention at all of loading waveforms from a USB stick - only saving waveforms to it. Two emails to tech support have gone unanswered......
Wing N
Post by Wing N » June 26th, 2015, 3:17 pm
The current version of ArbExpress does not recognize AFG1022. However, it is using the same waveform file format as the AFG3000. That is why the datasheet states specific to load the waveform using USB flash drive. You could create the waveform in ArbExpress and save as the .tfw waveform file and then load to the AFG1022 using USB flash drive. But, you can't do a direct transfer to load the waveform directly to the AFG1022.
shadychris
Post by shadychris » June 29th, 2015, 3:37 am
Thanks WCN. Tek support finally got back to me and told me pretty much the same. Seems poor that a new product is introduced without also making the software properly compatible with it first.... Is there a new version of ARB in the offing that will actually support this product??
I have now figured out that after pressing the 'callout' button the way to display the waveform is to keep pressing 'back' through the menus.. Nil points for the manual completely failing to describe loading waveforms from USB. The manual is called a 'quick start user guide' which kind of suggests that there is also a 'full' manual but I can't find such a thing on the website.
I've also noticed that regardless of the pp or frequency values set in ARB any waveform imported into the 1022 seems to default to 4.25Vpp at a frequency of 5kHz. Similarly a waveform created on the 1022 and exported to ARB always displays in ARB at 2Vpp regardless of the value set on the 1022.
Carl M
Post by Carl M » August 13th, 2015, 8:17 pm
ArbExpress is free (no-cost) software. It is covered under our Software Download Agreement: http://www.tek.com/software/software-download-agreement
ArbExpress is only intended to introduce the concept of arbitrary waveforms. typically, customers use MATLAB or Python for advanced waveform synthesis. Since these are already fantastic tools, I personally don't see any way we could improve them even if we charged for ArbExpress.
PhilW
Post by PhilW » October 22nd, 2015, 3:10 am
Hi. Having also just purchased an AFG1022, I have similar issues as with ShadyChris.
- I have been able to use ArbExpress(v3.1) to create waveforms, save them to USB stick, insert stick to scope and load them. Noting that since ArbExpress still doesn't support this instrument you have to pretend you have an AFG3000 and ignore the consequentially incorrect sample rate shown, but this method works.
- I can connect the AWG1022 by USB to the (Windows 7) PC, and it appears as a USB Test and Measurement Device (IVI). However, ArbExpress still says "Arb: Status: Not Connected", and if I try to connect using Communication->AFG/AWG File Transfer and control, I get a blue screen of death.
- Having created a number of waveform files I now wish to use regularly, I would like to save these to internal memory (since it seems that if I use external USB waveforms these are not reloaded at start-up, even with PowerOn set to Last).
Please could Tektronix consider offering better support for this product; I would suggest any/all of the following would dramatically improve the usefulness and usability of the instrument:
- Update ArbExpress to support AFG1022 for waveform generation
- Update ArbExpress to support AFG1022 for direct waveform file transfer
- Provide Matlab example code to generate and load a waveform to a USB-connected AFG1022
- Publish the file format specification for .tfw waveform files, so we can create our own in any tool of choice
PhilW
Post by PhilW » March 8th, 2016, 1:50 am
There has been no reply/response to my post above after five months.
If updates to address the ArbExpress issues are not likely (if it is no longer being supported) then please could I strongly request either
(a) Example Matlab code to generate a simple arbitrary waveform file, or
(b) The .tfw waveform file format to be made public
(I realise both of these are effectively the same thing, since to someone familiar with Matlab creation of the waveform data itself is trivial).
At the very least, a response of some form would be appreciated.
marcinstopa
Post by marcinstopa » May 19th, 2016, 6:00 am
That was the case maybe 15 years ago but is no longer true. Tek was the leading manufacturer in analog oscilloscopes, but their digital scopes were mostly pretty mediocre, and these days Tek is way behind Agilent/Keysight, LeCroy or R&S in quality, support and even more so in technology. With few exceptions these days with Tek you're paying mostly for the name.
For entry level scopes go Rigol (if you can live with some of the quirks) or Agilent/Keysight or Hameg/R&S, and for mid-range or high-end scopes go for LeCroy (which is pretty much the leader in digital scopes).
For AWGs, if you want a decent entry level one go for Rigol or Siglent, and if you want something more advanced go for Agilent/Keysight (if you want highend then I'd also consider Tek).
JoeDini
Country: Canada
Post by JoeDini » June 30th, 2016, 9:12 am
Hi everyone...i am new user here and also the new user of ARB. As per my experience the current version of ArbExpress does not recognize AFG1022. However, it is using the same waveform file format as the AFG3000. That is why the datasheet states specific to load the waveform using USB flash drive. You could create the waveform in ArbExpress and save as the .tfw waveform file and then load to the AFG1022 using USB flash drive.
