AFG3022B invoke external trigger with matlab
Lilian
Country: France
Post by Lilian » May 23rd, 2016, 2:01 am
Hello
I want to ivoke an external trigger on my AFG3022B using matlab.
I know that the command is:
invoke(deviceObj,'trigger');
this command use to work perfectly for month, but now, it says:
Index exceeds Java array dimensions
and i don't know why.
i saw using the debugging mode that in the "invoke" code, the variable " tempOut" is a 0x1 java.lang.Object[], witch i assume is not normal.
Could you help me?
Sincerely
Lilian
