AFG1062 trigger interval via USB
Pooja_m
Post by Pooja_m » June 21st, 2017, 12:45 am
Hi All,
Does anyone know whether you can control the internal trigger interval of the AFG1062 through USB? I tried to find that command from the programmer manual, but did not find it there.
The waveform is pulse, in burst mode. You can control the trigger interval externally by pushing the burst and selecting the trigger interval.
Pooja
Re: AFG1062 trigger interval via USB
Post by David N » June 27th, 2017, 8:39 am
Trigger interval can only be controlled from the front panel. These is no programming control for this function. If you need programming control of this parameter, you may want to consider one of the AFG2000 or AFG3000 series instruments.
