AFG1062 doesn`t manually trigger at new Arbitrary waveforms
norbrunner
Post by norbrunner » August 25th, 2017, 7:53 am
We are using the AFG1062 with version V 1.0.4 for generating single pulses which are generated as new arbitrary waveforms. These self-generated waveforms are not outputted by manual trigger button while all the others pre-defined are working. Is this normal or a bug?
Norb
Bryan B
Re: AFG1062 doesn`t manually trigger at new Arbitrary waveforms
Post by Bryan B » September 7th, 2017, 9:18 am
Could you clarify what you mean by "all the others"? Are you outputting on multiple channels and the channel with your pulse arbitrary function won't output when manually triggered?
norbrunner
Post by norbrunner » September 25th, 2017, 5:13 am
"all the others" means e. g. Sine, Square, Ramp, Pulse and also built in arbitrary waveforms... Only self generated arbitrary waveforms couldn't be triggered manually. But they are outputted at continuous.
I'm only outputting on one channel.
TobiasSchlueter
Post by TobiasSchlueter » November 15th, 2017, 2:19 am
I got a similar problem, but with the external trigger.
I can trigger any waveform external, but when i make my own waveform i got no output.
The customized waveforms only can be generated in the continuous mode.
Is there any help?
Bryan B
Post by Bryan B » November 20th, 2017, 10:14 am
Hi Tobias and Norb,
I'd like to collect some more info on this, please contact us at [email protected] with your contact info and put to the attention of me (Bryan).
flov27
Post by flov27 » January 16th, 2018, 11:51 pm
Hi there,
I have the same behavior like TobiasSchlueter. Is there any update yet?
Post by David N » January 17th, 2018, 2:23 pm
I would suggest setting the modulation mode to “Burst”, set the burst cycles to “1” and set the trigger to “Manual”.
Also as of 1-16-18, firmware V1.0.5 is now available on Tek.com if you would like to update to the current level.
