I am trying to get white noise
marcelbombka
Post by marcelbombka » September 22nd, 2017, 3:41 am
I am trying to get white noise to test a filter, but AFG3252 seems to generate tiny output (-60dB) Any suggestions? Thanks!
Re: I am trying to get white noise
Post by David N » September 22nd, 2017, 10:49 am
If you are just using the Noise function in the AFG, you should be able to set the output amplitude as high as 5 Vp-p. If you cannot it may need repair.
I would recommend submitting a support request so we can further understand your application and how you have the AFG set up for you application.
You can submit a support request at: https://www.tek.com/support.
